There's nothing wrong with that....
No, it’s not like a kitchen pot with thin enamel. You need to read about how the coating is applied, it doesn’t break off or crack like glassMost tanks, by very definition, are "glass lined". No, not thick like a pop bottle, but thin like an enameled kitchen pot. The material DOES break and crack under certain stresses. When it does water then hits the steel tank and then corrosion and rust begin. If the glass never cracked or never got damaged, there's no need for an anode rod!
There is definitely a way to get the anode rod out, but like others have said, it may not be worth it. You can weld a 1" nut to the head of the anode rod, and then use an impact gun to remove it. Of course, you need an arc welder, the skill to do it, and a powerful enough impact gun. And that may also damage the tank, but you'll get that damn thing out!Are you guys saying there is no way to get the rod out now that the bolt is rounded? Hate to have to replace the tank in a couple years because I can't replace the $35 anode. The tank is attached with flex lines, both gas and water so a little movement is not going to break a line.
except there always seemed to be that one bolt left over after reassembling LOL. I've learned in my old age to take pictures as disassemblingThere's nothing wrong with that....
Just like my son. At 12 years old, he would disassemble radios and TV's, just to see if he could put it back together correctly. He is now the Range master and master Gunsmith for the largest Sheriff's Department in the United States.LOL I am the curious type. As a kid I would disasseble things and put them back together just to see how they worked.
I read up on it. Begs the question is there any advantage to building a stainless steel tank?The tank doesn’t have glass that breaks like most people think. Look up and read the process of you’re interested.
Sure are and there are stainless tanks made.I read up on it. Begs the question is there any advantage to building a stainless steel tank?
This would be the way I’d go about it if I was forced at gunpoint to remove the anode.There is definitely a way to get the anode rod out, but like others have said, it may not be worth it. You can weld a 1" nut to the head of the anode rod, and then use an impact gun to remove it. Of course, you need an arc welder, the skill to do it, and a powerful enough impact gun. And that may also damage the tank, but you'll get that damn thing out!
If you truly found a replacement anode with a PLASTIC bolt head it is the LAST type I would utilize. Steel only.The interesting think is that the new anode rod that i bought has a plastic head/bold. Don't know if that will make it easier or harder to remove in the future...
All of that can be cut away if a guy was determined. Then reapply the foam and a patch to the metal.Some of those anode nuts are down 2-3 inches deep because of the insulation. Have fun trying to weld a nut on those.
Agree 100%!All of that can be cut away if a guy was determined. Then reapply the foam and a patch to the metal.
But I dont replace anodes.
Nor does that seem like a reasonable design. For an anode rod to work, there must be an electrical connection between the rod and the tank. So, there would have to be some part of the anode rod connected to the tank at the threads, one would assume.If you truly found a replacement anode with a PLASTIC bolt head it is the LAST type I would utilize. Steel only.
Doesn't seem feasible ... plastic head on metal threads ???
Top of my anode is only about 1/2" below the top of the tank so it is accessibe. It would be nice if they put them above the tank so a wrench could be put on the anodeSome of those anode nuts are down 2-3 inches deep because of the insulation. Have fun trying to weld a nut on those.
This is the anode I got at Lowes. I didn't open the package in case I can't get the old one out and need to return it but looking at it closer thru the plastic, I now believe the threads are steel and just painted plack making it look like it was plastic.Nor does that seem like a reasonable design. For an anode rod to work, there must be an electrical connection between the rod and the tank. So, there would have to be some part of the anode rod connected to the tank at the threads, one would assume.
I agree. It really sucks to get them out. They must put them on with a machine or something.Top of my anode is only about 1/2" below the top of the tank so it is accessibe. It would be nice if they put them above the tank so a wrench could be put on the anode
