Valve identification
Discussion in 'Showers and Tubs' started by Frank Langer, Dec 14, 2018.
  1. Dec 14, 2018 #1
    Frank Langer
    Frank Langer
    Frank Langer
    Dec 14, 2018
    13
    Ohio
    Can someone help me identify the fixation ring or the pressure balancing valve on this shower valve. I don’t have any numbers. It’s an American Standard Valve. The trim kit is Seva. It’s approximately 15 years old. I’ve looked many places and cannot find the identical shape that matches the fixation ring! Hoping someone has seen it and remembers it.
  2. Dec 14, 2018 #2
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    110
    15
    Remove the screws and take out the tumbler. Call any wholesale house in your town and drop in and pick one up. I think....and I could be wrong, there is only one tumbler(balancer) for that valve.
  3. Dec 15, 2018 #3
    Frank Langer
    Frank Langer
    Frank Langer
    Dec 14, 2018
    13
    Ohio
    Thanks for the reply. I have had the balancing unit out and, regretfully, it is not a standard balancing valve. It is an oddball balancing valves and that’s why I am trying to see if anyone possibly recognizes the face on this balancing valve. I’ve shown this same picture to a plumber and a guy at a plumbing supply house and neither one could positively identify the unit.
  4. Dec 15, 2018 #4
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    110
    15
    Put up a picture of the trim.
  5. Dec 15, 2018 #5
    Frank Langer
    Frank Langer
    Frank Langer
    Dec 14, 2018
    13
    Ohio
  6. Dec 15, 2018 #6
    Frank Langer
    Frank Langer
    Frank Langer
    Dec 14, 2018
    13
    Ohio
    Here’s the trim package. It’s called Seva.
  7. Dec 16, 2018 #7
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    110
    15
    I found 4 different pressure balancing spools numbers. Bad for you. Send your pictures to this email. Rollinsa@lixilamericas.com This is a person that identifies American standard parts. Her name is Anna Rollins. She can tell you which parts you need.
  8. Dec 16, 2018 #8
    Frank Langer
    Frank Langer
    Frank Langer
    Dec 14, 2018
    13
    Ohio
    Thanks you for the reply, your research, and the contact at American Standard! Your help is greatly appreciated! I will send the photos for sure.
  9. Dec 20, 2018 #9
    Frank Langer
    Frank Langer
    Frank Langer
    Dec 14, 2018
    13
    Ohio
    Thanks to RenewDave! I heard back from Anna Rollins at American Standard. She helped me identify the balancing spool and we have it on order. Thanks for the recommendation. Much appreciated!
    havasu likes this.
Share This Page
