Tub spout replacement - go with IPS or CC
MissB93
Mar 18, 2011
St. Louis, MO
Tub spout diverter has finally died (type you pull down from under the spout to engage). It is fine with me as it is a cheap plastic builders special that is over 13 years old and no longer matches anyway.
I had installed a Moentrol valve and handle several years ago (matches sink), but we did not replace spout.
I can still buy a Moen spout that will match the shower handle and sink faucet. Problem is, the connection options are IPS (front threaded) or CC while the old spout connection is 3/4" adjustable/telescoping. There is an adapter on the 1/2" copper pipe that was soldered.
No matter what, I'm going to have to remove the existing adapter. I have the capability and experience to remove it.
What I want to know is:
A) How well do the CC type attachments work?
B) If they do not work as well as IPS, when I pull off the old adapter, is there an IPS one I can solder on to the copper pipe or am I going to have to replace the pipe further back in the wall?
