Furry Orca
Active Member
Yey! The project is complete and water pressure is regulated and back to normal. The plumber, nice guy by the way, ended up having to sweat and solder afterall. In fact, Shark Bites would not have worked. He verified that there was only a 1/4 inch or so of play in the pipes for maneuverability. You need an inch for Shark Bites. He ended up having to cut the pipe on the side of the PRV closest to the front of the water heater and the side furthest from the back wall. So, he cut the pipe on the side to which the water flow arrow was pointing. He refitted a new coupling with some additional pipe cutting for fitment purposes and made the new unit double union for ease of replacement when this new unit fails. What took him a while was the pesky o-rings. He must have had a pretty tight fit because he kept on crimping them. I think he went through two or three before he relented and used washers instead.
Here are some pics of the new double union PRV installed and functioning as hoped and designed.
Here's a closer look at the part of the piping that was reconfigured to accommodate the double union considering severely limited play in the piping.
As I mentioned, it is now working as hoped and designed. Pressures are now regulated and normalized. Here is the reading from the front hose bibb. I adjusted the screw on the PRV to a psi of 53. When another tap is drawing, there is a consistent 5 psi drop which is expected and reasonable.
Here's the backyard hose bibb reading. It's consistent with the front yard hose bibb.
Mission accomplished. Next time I won't need to use a plumber to replace this fixture and in the meantime maybe I will practice sweating and soldering just for the hell of it in preparation for replacing the water heater which is also 18-years-old.
