We live in a 1932 home. One of our guest bath sinks has spring loaded hot and cold valves each with a faucet like you see sometimes in public restrooms so people can't leave the faucets running when they leave.
Dumb idea for home use though. You can't run the water and let go of the valves so it's impossible do anything for more than a second before the valves close. Can't wash, can't wet a wash cloth or fill a plant watering can, etc. Dumb.
Is it possible to convert these vintage looking spring loaded valves to typical non-spring values that stay open when you let go and so we can keep the look of the bathroom. I'm sure we can find a replacement online, but I'm hoping it's an easy fix and I can simply remove the springs or replace an internal part and keep the outer parts and not change the look of the hardware with a complete faucet replacement?
I took off the top part which revealed an inner mechanism I've never seen before in the 3rd picture (3_0326). This mechanism doesn't unscrew or seem to have any intuitive way to remove it.
But in taking pics for this post, I see in #4 (4_0330) there's a large nut I assume can be loosened to get into the inner valve? But I thought I'd ask before blindly experimenting since this whole mechanism is totally foreign to me.
Thanks for any insights.
Regards,
Steven
Regards,
Steven
