uthorns1976
Today, I attempted to replace a hose bibb that had a very, very slight drip. The hose bibb was attached to a galvanized pipe that comes out of the ground. The hose bibb was basically at ground level. I had to be on my knees to attach a hose to the faucet. When I attempted to remove the old hose bibb, the galvanized pipe cracked. So, then I was in over my head. I managed to get a plumber out to fix the problem so the water could be turned back on. The plumber dug deeper than I had and found that the old galvanized pipe had apparently been leaking for a while. I left the plumbers alone to do their work. When I went to check on the status of the work, I found that the work was completed and the plumber appeared with my bill. I paid him and he left.
The plumber replaced the galvanized pipe with a 1/2" copper pipe sticking out of the ground 16 inches and an angled hose bit attached to the copper pipe. The hose bibb points skyward. Needless to say, the 1/2" copper pipe sticking out of the ground 16 inches is not resilient and it will have to be insulated in the winter. This is not what I would have done by any means.
If I want to remedy this situation, how should I proceed?? One thing I know I want is a hose bibb that does not point skyward. The old hose bibb pointed straight out, not upward at an angle. Also, I want a more sturdy pipe attached to the hose bibb, not a flimsy 1/2" copper pipe that extends 16" out of the ground.
Thanks in advance for input.
