JG plumbing
You'll have to dig a little. It screws onto a male adapter and you'll need a little rock.
Your probably going to want the shortest one you can find since it sounds like your water line isn't deep.
This also might require you drive a long stake along side it once the water line is exposed, also since your not very deep. The earth usually holds these up since a good portion is buried. You'll rely on the long stake you drive. Then use some stainless tie wire to marry the steak and the riser.
You can start this video at about 6 min in and see if you want to do it.
