So, the bathroom sink was draining slowly. I took apart the trap and tailpipe and cleaned them, but the problem persisted. Next, I snaked the line past the trap. There was very little dirt in the line and the snake ran freely for at least 10 feet. When I assembled the trap it was leaking from where drain connects to the gray tail pipe. So, I replaced the trap and now the problem is worse! Water is standing in the sink.
The sink is the middle fixture with the bathtub to its left (last fixture) and toilet to the right. Both the tub and toilet drain without a hitch, so I am assuming that the main line is not clogged. Lastly, it does not take much water to clog the sink. It's not like the water is flowing to a certain point and then stop draining.
For reference, I attached a photo depicting the old trap and the new trap. Replacing the assembly gave me a water tight drain with no leaks; however, now there is zero drainage.
I am not sure but I believe the standing water problem began when I replaced the drain. Prior to that I believe it was draining slowly. But that could be attributed to the fact that it was leaking at the tailpipe to drain connection.
Any thoughts or suggestions would be greatly appreciated!
