Random plumbing pics
It looks like the water leak is there for awhile to cause that much damage.
6 years. The front wall of this home has a 1/2” layer of OSB ply on the outside and inside of the wall. As you see the drywall was in pretty good shape, not even much mold on the paper backing. Very deceiving from the outside of the wall.
I used a FLIR camera to scan the wall and I thought my equipment was failing…..it showed a big cool spot indicating water but the drywall wasn’t wet.
The upper deck has a beam that’s tied into the framing and that’s where the water was coming in.
The other side of the porch has the same issue.
I had to change the tag on my propane yard equipment before I got a ticket. The county yard equipment inspector was checking my street…..795DC2B2-2A54-4E51-BADE-CEB74FF68E97.jpeg
I can't tell if you're joking or not. Is that an actual thing? Having tags like that for lawnmowers?
