davidmsem
Do you leave the flow restrictors in your shower heads ?
What brand shower valves did you install ?I have new shower heads on order for the remodel bathroom. are you referring to the screens or is there something else I should remove. I certainly would remove them. I ran 3/4-in plumbing all the way to the second story and up to the valves to try and maximize flow. not sure if it will have an impact or not.
Meon.What brand shower valves did you install ?
There is typically a flow restrictor that’s separate from a screen.
If you remove the screens and trash gets into the head, it can ruin it forever. I don’t recommend removing the screen for that reason.
Are the Moen showers where you’re experiencing the “ low pressure “ ?Meon.
Pressure on the house is okay, but not great. i lived with city water growing up. could have spoiled me.Are the Moen showers where you’re experiencing the “ low pressure “ ?
If you want a system that mirrors constant city water pressure, you really need to seriously consider a CSV. Constant pressure, no surge when the switch starts the pump, just like in the city.i lived with city water growing up. could have spoiled me.
It is your water system. You can have as much pressure as you want. You just have to make it happen. The constant pressure from a Cycle Stop Valve can be much better than city water pressure, it is not just mirroring city pressure. I don't think you need 90 PSI, but you could have that or more if you want. A 60/80 switch with a constant 75 PSI from a CSV should even eliminate the need for soap in the shower. Lol!Pressure on the house is okay, but not great. i lived with city water growing up. could have spoiled me.
Thank you . I'm thinking the first change is to a 50/70, up from the 40/60 I have now. I would need to increase the air pressure in the holding tank I believe when I change the pressure switch.It is your water system. You can have as much pressure as you want. You just have to make it happen. The constant pressure from a Cycle Stop Valve can be much better than city water pressure, it is not just mirroring city pressure. I don't think you need 90 PSI, but you could have that or more if you want. A 60/80 switch with a constant 75 PSI from a CSV should even eliminate the need for soap in the shower. Lol!
I use 50/70 with 60 PSI constant from my CSV and it almost peels my skin off in the shower.
On the contrary, starting and stopping a pump with a pressure switch is what is "unhealthy" for any pump, or for any electric motor for that matter. Repeated inrush current on a motor can cause the motor windings to overheat. There are actually many motor installations that have instrumentation preventing the repeated starting of a motor over a certain short period of time.even if it is unhealthy for the well pump
Just the opposite is true. The CSV makes pumps/motors last much longer than normal. The propaganda that says a CSV is "unhealthy" for a pump is put out by those who want you to purchase a new pump every 5-7 years instead of every 30-40 years. I was never a conspiracy theorists before. But having accidentally come up with the cure for pump cancer I have certainly been the target of many misinformation campaigns. I have learned that efficiency and longevity are a negative to manufacturers. Planned obsolescence is the primary goal. Manufacturers will exaggerate performance and/or outright lie about efficiency to get people to purchase their most profitable items. Over the last 30 years I have learned to distrust everything.even if it is unhealthy for the well pump.
