peacepipes
Why is there is there calcium coming out of our hot water recirculation pump?
Should I Fix this?
How?
(Thank You......)
Should I Fix this?
How?
(Thank You......)
I'm still trying to figure out the orientation of the pump in the pic. Which way is up???
Can you see it here?
Okay so now I really got a question. If that's a tankless unit Why does it need a circulating pump?
So which one is this in the pic? And as mentioned before, why the circulator?
OK< somebody help me out here. A tankless water heater is fired up by turning on hot water somewhere downstream of the heater. "Right"? So when there is no water being used the tankless unit will be "Off" "Right"? So why the circulation? You would be circulating the same cold water which would be useless.Instant hot water at fixtures. Navien is the brand I install and it has a circ pump built into the unit. A lot of homeowners confuse a tankless heater with instant hot water.
