I am going to tough it out with the well guy. I may have to install it myself, which is silly because I need the tank tee replaced because of corrosion and they will be installing a softener and neurtralizer. I was looking on your site yesterday and I see there is a valve-LT kit that has a tank tee included. Is that kit more for the smaller tanks. I have a typical blue Amtrol tank. When I was looking up the valve installation pictures, it shows my typical setup and then the smaller setups where the valve is on top of the tank, like in the above video. Does your tank tee apply to my set up or is it more for the smaller set up? I like that your set up was stainless steel. I really appreciate your help with this. Thanks.
BTW, I did see on your site that you adjust the valve to 57 psi with a 62 gallon tank, like I have. I am thinking that my tank will supply the pressure for most toilet flushes and occassional sink uses and that the CSV will really come into play with my irrigation. Do I have this right and why do you adjust pressures for different sized tanks. Thanks.
