pnovak
I'm going to install a recirculating pump. I'm thinking a unit with the sensing valve like the Watts
cause I don't have a dedicated recirc line.
I'm going to put in more than one valve cause my usage points are quite apart from each other.
I'm planning on a remote start for the pump, because I want it to work on demand, but I have
concerns about the sensing valve operation.
What happens if the pump runs for a long time, but the valves shut off the water flow because
their criteria have been satisfied??
Real life example: I'm planning on a remote controlled electrical outlet to control the on/off of power
to the pump. I turn on the outlet, but neglect to turn it off and go out for the day. Have I burned out
my pump??
thanks
my pump??
thanks
