Hi, first time poster and have been stumped by a potential issue with my toilet.
After either using it (#1) or pouring some water in as a test, I hear a fairly immediate trickling in the drain. Not making the noise when not in use. From other threads I've searched it seems this typically is just the water displacement but what I'm stumped about is, I just started hearing this today, after years and years of using the same toilet so I'm a bit confused since a lot of the similar issues I read were traced to new installs that created a new noise so to speak.
Since there's no new construction in the surrounding area, not a new toilet and I'm not seeing any leaks, nor hearing anything when it's not in use and my novice visual inspection of the tank components seems fine, fill tube, flapper (could probably replace anyway but for now seems seated fine/no drip noise), etc, the obsessiveness in figuring this out is killing me haha.
Like what would suddenly cause this noise to occur at this point in time? Is it possible the p-trap is more full than it was before for some reason? It seemed to start after a toilet cleaning but that seems coincidental to me. Is there potentially some mild blockage somewhere that needs remediation? I'm trying to wrap my head around why now (and to ask the fine folks in here if this could be the beginning of some bigger issue I'm not aware of).
I tried running some surrounding fixtures but that doesn't seem to trigger the noise, so I'm not sure if it could be the seal wearing away (can that happen over time?). I see no water on the floor thankfully. It's on the upper level and a subfloor is between that and the bottom floor but I should probably still see some signs of water if there was a leak I think. Water level in the tank and bowl seem normal to me.
I don't know, I'm stumped as to what would cause this noise to start after so many years and just wanted to make sure there wasn't something that was going to get worse over time and be much more costly than just addressing it now. Problem is I can't figure out what that is lol.
Thanks so much, hope you all have a wonderful weekend.
