Quantcast
Toilet water lowers when draining tub
HereinVa
Nov 8, 2020
Virginia
So here goes....
When I drain my guest bathtub, the toilet water lowers at least an inch. Also, the toilet flushes with too much or not enough air, it kind of labors but functions fine otherwise.
Ive manually snaked roof vent, tub drain and the toilet-not sure if I went far enough, only have 25ft auger.
Finally, the outside sewer cap/clean out pipe goes down horizontal like. I snaked that and went as far as it could go. Still no fix.
The picture is the interior drain pip on bottom floor. Can I snake there?
What am I missing? Totally off the trail?
Thanks
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,404
413
Boston, Massachusetts
It sounds like you have venting or lack of venting issues sounds like the toilet is being siphoned when the tub drains, I think that's why your toilet doesn't flush like it should
You didn't say whether this just started
Or always has been an issue that would be helpful
HereinVa
Nov 8, 2020
Virginia
Hey,
The toilet flush problem has been 4 months or so. The water lowering was noticed around 2 months ago-maybe.
I only noticed the water draining slow out of the tub when my wife told me. I then happened to look at the toilet and water lowers every time it drains. Overall the last 6 months is a good time base.
thanks
Jeff Handy
Jul 5, 2019
2,750
606
Chicago suburbs
You probably still have a partial clog in a drain line.
Probably time for a pro to snake all the affected drains.
You might have snaked into a clog but not enough to break it up.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,404
413
Something that's stuck in your toilet is acting like a wick you need to pull the toilet and check the outlet of the toilet and while the toilets off run a long snake dow the drain so you know that's clear
HereinVa
Nov 8, 2020
Virginia
Thanks everyone.
I did the toilet already but, I certainly didn’t get too far past the bend. I’ll try again and get back to y’all.
cheers
Jeff Handy
Jul 5, 2019
2,750
606
Chicago suburbs
You can get about three to six feet with a toilet auger, depending what model you have.
Snaking through a toilet with a skinny little snake made for a sink drain does not work.
It is too skinny and will just whip around if it hits anything.
It won’t dig into a clog, because the walls of the drain are too wide to keep the floppy snake under control.
You can push a thicker snake through a toilet, but it will usually mark up the bowl very badly, sometimes you can clean up the marks with ultra fine wet sanding paper.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,404
413
I ment to snake dthe main drain when you had the toilet off
