newbiehomeowner
Hi all -
I've learned a lot on this forum and am very grateful. I wanted to get your feedback on the following I've noticed with my sump pump.
Sump Pump Model: Barmesa 2SEV512
The pump pumps up about 1-1.5ft to a horizontal pipe that runs about 500 feet away from the home.
1) Earlier today, I tested the sump pump by running a hose in the sump and it was pumping some water out (a trickle, definitely not the normal amount), but then the pump itself began vibrating and shaking as the water level rose in the basin.
2) I disconnected the sump pump, submerged it in a bucket of water, and it was able to pump properly onto my lawn, which told me the pump was still operating and not burnt out.
3) I waited for a while, then I reconnected the pump, went to test it again. This time, the pump worked perfectly and was able to empty the basin multiple times without fail.
4) The only final thing I noticed is that after the pump emptied the basin at the end of my test, it started making a strange gurgling noise
I have 2 questions:
1) Any ideas as to why the pump was shaking/vibrating and not pumping, yet worked perfectly after disconnecting/reconnecting?
2) Any sense what the gurgling noise is after the pump shuts off?
Thanks so much!
I have 2 questions:
Thanks so much!
