TDELMASTRO2012
I am trying to figure out what type of stem valve this is. It's for a shower transfer valve to switch the water from the overhead to the handheld. The stem is 1" long. It's getting stuck and I need to replace it.
Thank you. I simply want to replace the cartridge. When I try to unscrew it using a wrench on the brass hex nut it does not budge. There is also cement around the outer ring which I assume is the valve sleeve.You have a Moen shower valve. I’m not sure by looking at your transfer stem what brand it is.
You need to remove that transfer valve cartridge from that valve and take another pic.
A big wrenchOk. I think it's extremely stuck due to the mineral buildup. Is there anything I can put on it to help losen it?
Thank you. How deep are those sockets and how long is that rachet?
