bdmeyer
Active Member
I have been at this for several weekends now.
The problem is, when I turn the shower on, in less than one minute what starts out as a full stream, ends up as a trickle. This began about 6 weeks ago, I did some reading, and thought I was ready to fix it.
I have a delta single valve and a divertor mounted on the bathtub spout.
First, I replaced the Shower head. Nothing changed. Next I rebuilt the Shower valve by replacing the two springs and seals. Nothing changed.
I replaced the valve with a Danco, and Now the pressure coming out of the Spout is noticeably stronger when at at the middle position.
I moved the divertor to the 'shower' position, and it was the strongest stream I remember ever seeing from that shower. I've lived int he house about 7 years.
In less than a minute, the stream was very weak. No more dribble like before, but I am guessing maybe one fourth to one fifth of the full initial stream.
I thought, "Why not put the valve in the middle position just to see what happens (lukewarm, max cold/hot mixture)"
I did this, and didn't see much difference.
I bought a new Spout / Divertor.
Did the same thing, only now, I have two new problems:
1.) Merely turning the water on through the spout, and the water comes out of the spout AND the shower head.
2.) I have a non stop water hammer when I put the valve int he middle position.
I watched some videos on the cause of water hammer, and see I likely need to drain all the water from my house, to bleed the air out. I haven't a clue where the highest elevation is, as it is a single story structure.
I know where the water enters the house, so I will take a wild guess that maybe that is the highest elevation? (City Water)
The spout / divertor is a Sioux Chief Universal self tightening model, that i preferred over the plastic ones I saw at the Home Improvement places.
Any advice will be taken gratefully. I have no access panels, My house is on a concrete slab. I have looked inside the wall when I was replacing the valve and there was no water leak.
Thank you,
-= Bruce D. Meyer
Thank you,
-= Bruce D. Meyer
