Shower mixing valve
Discussion in 'Showers and Tubs' started by Vanessa1989, Jan 17, 2020.
  1. Jan 17, 2020 #1
    Vanessa1989
    Vanessa1989
    Vanessa1989
    Jan 17, 2020
    Austin tx
    Hi
    I have a shower mixing valve that I cannot seem to figure out how to adjust. It just doesn’t look like anything I could find online. Can anyone help ? See photo
  2. Jan 18, 2020 #2
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,430
    1,344
    Southern California,
    What are you trying to adjust?
  3. Jan 18, 2020 #3
    Vanessa1989
    Vanessa1989
    Vanessa1989
    Jan 17, 2020
    Austin tx
    Hello
    The water temperature is only cold so I need to adjust the anti scalding valve but I can’t figure out how.
    I will also add that the water pressure is great when turned to the cold but dramatically decreases when I turn to the hot.
  4. Jan 18, 2020 #4
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
    Sounds like the pressure balancing module is bad.
    Sometimes it is built into the shower cartridge.
    However it is often a separate cartridge or module, sitting behind the cartridge, further inside the valve body.
    And what is that second valve on top, does that divert water to body sprays or a hand shower or something like that?
  5. Jan 18, 2020 #5
    Vanessa1989
    Vanessa1989
    Vanessa1989
    Jan 17, 2020
    Austin tx
    Hey there,
    thank you! Yes the second valve diverts the water to a hand shower.
    do we need to unscrew that last brass piece to get to the other cartridge to adjust?
  6. Jan 18, 2020 #6
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
    That top hand shower diverter likely has no effect on hot water output.
    That red ring on the lower main valve looks to be a limiter, it has a bump on it that stops the shower valve handle from turning all the way to full hot, usually as a safety to avoid scalding.
    I don’t know the brand of valve, but it looks like you can unscrew the brass cap on the main valve by gripping those two flat spots with a big Crescent type wrench, or some really big Channel lock pliers.
    To access that red limiter ring.
    With the house water off first, of course.
    And open the valve to let shower water pressure out, and open a faucet lower down in the house or nearer the meter, to let some water drain out first.
    That way less water bubbles out of the valve and less water gets into the wall behind the valve during this procedure.
    That red ring can likely be inserted in several positions, to allow more or less movement of the valve handle towards the full hot position.
    Vanessa1989 likes this.
  7. Jan 18, 2020 #7
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
  8. Jan 18, 2020 #8
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
  9. Jan 18, 2020 #9
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
  10. Jan 18, 2020 #10
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
    If the hot water limiter ring adjustment is not the problem, then you need a new cartridge and/or a new pressure balance module, if that is a separate part.
  11. Jan 18, 2020 #11
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
  12. Jan 18, 2020 #12
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,295
    219
    Chicago suburbs
  13. Jan 19, 2020 #13
    Vanessa1989
    Vanessa1989
    Vanessa1989
    Jan 17, 2020
    Austin tx
    Thank you SO much that is very helpful. We were thinking this, but didn’t want to try it if we weren’t 100% sure.
    We will shut off the water and give it a shot.
    Thanks again!
  14. Jan 26, 2020 #14
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,368
    409
    North Reading, Mass.
    I assume Vanessa was looking for a simple tutorial showing how one adjust for flow and temperature settings.
    I don't see it anywhere.
    Call the company and ask them to send it if it's available.
Draft saved Draft deleted
Share This Page
Group Builder
