Shower Cartridge - HELP
Dannyboy
May 17, 2019
Toron
Hello,
I recently purchased a house and quickly realized the master shower had no hot water. I had a plumber look at it and advised that the shower cartridge needed to be replaced. Here is where things get tricky. The shower does not have a shut off valve. I have emailed pictures of the installed cartridge to a number of plumbing supply store and no one can identify it and they want me to bring it in. If I turn off the water to the house and the cartridge breaks when I remove it, I believe I am screwed. Correct? Any thoughts on my next step?
Thank you for your help
Kevin Monahan
May 17, 2019
10
Boston
It looks like it could be either of the cartridges below. It may be neither though. What I am unsure of it what retains it in the valve body. Thermostatic valves are usually threaded in, or have some sort of spring clip/trim that hold them in. Both of the cartridges that I found have a set screw in them (something I’ve never seen before). I imagine you screw it inward for removal, and screw it outward for installation? I found a YouTube video that shows the set screw being in the right side. The tilers didn’t do you any favors so you can’t access the integral stops(something I have encountered a lot before). Although I usually avoid using integral stops when I can anyway. As long as you find what holds it into the valve, I’ve never damaged this type of valve irreparably.
https://www.chicagofaucetshoppe.com/product-p/hud-spn322c.htm
https://www.divapor.com/spares/showers/thermostatic-cartridge/mz-del-rio-ct0046-99-thermostatic-cartridge-for-eco-shower-mixers.php
Dannyboy
May 17, 2019
Toron
Thank you Kevin. I think I have to remove the cartridge. there is set screw at the bottom. I wonder if there is a way to removr it without cutting the tile. The screw sit just above the tile opening. Very tight fit
Have a nice evening
Kevin Monahan
May 17, 2019
10
Boston
If it’s an Allen screw, you may be able to cut an L shaped key down to get it to fit. If that doesn’t work, it looks like you’ll need to cut some tile away. Depending on how steady your hands are, a dremel, or an oscillating tool will work. You may want to call a tiler to do this for you though if you’ve never done it before.
