Patrick Green
This last month I had a plumber replace my drainage tile that was crushed in the backyard. The plumber could not replace the last 10 feet which leads into my house because of a concrete patio however water is flowing thru. The night after the tile was replaced we started to smell a strong odor of sewage inside of the house after running large amounts of water (washer / shower). The plumber came back out and installed a trap on the new tile he installed. The smell has continued and is very strong from the clean outs on the new tile. When I leave the clean outs uncapped outside it drastically helps with sewage smell. The plumber has also put dye to see if septic is leaking and did not see any in new tile. I was also told septic tank does not need pumped. Iam at a loss and don’t know what to do from here. Thanks for your help!!
