spotopolis
I sent this inquiry to RootX a week ago, but because I am a homeowner and not a plumber, they will not respond. I guess I understand that it is intended for plumbers, but I am a bit miffed that there was NO response. They sell direct to consumers now, so why ignore me?
My cleanout is only a couple of feet from the basement toilet. It is recommended to put 4 pounds of RootX plus 10 gallons or so down the line to clear 100' of 4" pipe. It is 100' from my cleanout to the main. I put the 4-pounds in the cleanout, and I have old 5 gallon toilets, so I flushed the upstairs toilet first, then ran down stairs to flush the basement toilet. By the time I got there, the basement toilet was overflowing with foam. Thankfully, I have a floor drain in that bathroom since it made a bit of a mess.
They recommend only putting 2-pound containers down the toilet, rather than the 4 for a cleanout, but 2 pounds is only good for 50'.
My question is, can I flush 2 pounds down first and then send another 2 pounds afterward? I don't want to wash away the foam, but I need to push it out 100'. If that can be done, how long between applications is appropriate?
Thanks for any advice.
