requirements for drain pan for Water Heaters
shaken-n-stirred
Jan 7, 2015
95
Site is Idaho - generally follows national codes
AM I required to have a drain for a water heater. If so what is required? Can I just have pan with a hose running to air (outside)? Do I need trap and vent?
Water heater is over crawlspace on the first floor. Wood framing (not slab). No floor drain planned.
International Plumbing Code would require a pan with a minimum of 3/4" drain, though I would go bigger, 1" minimum, and terminate it with a screened end to keep the bugs out. Use aluminum or galvanized pan.
