I have some water damage just outside the showers on both bathrooms that were installed by our builder before we moved in. Both showers us the same enclosures. The water damage is just outside the shower enclosure in the exact same spot on both showers AND because the enclosures are identical on both sides, we have two spots per shower that has water damage on it.
My question here is, I'm not sure what I should do. Both enclosures are made up of a 3-piece unit. I've taken pictures of the places where the water damage is and also where the three piece enclosure's seams are. I'm wondering, though if it's something as simple as water running along the cavity where the tub meets the enclosure, or if it's likely water is getting behind the enclosure? There is caulking all along the enclosure and there is a hole right where the water damage is forming.
Image one and two show the place where two of the three-piece enclosures meet and image three shows the water damage. You can also see that the caulking as somewhat failed there, but it doesn't seem to me that water is coming from behind, but rather it might be running along that seam.
Thank you for your help.
