itbedave
So I found out early this morning that it's NOT my 2 year old dishwasher that's leaking (I thought some food crud had built up along the seal on the bottom right, allowing water to escape.) No - it's my 15 y.o. ISE Badger 1 disposal that is leaking through the bottom and out the motor housing.
I'm not concerned about replacing that itself (ordered a new Waste King Legend 9930 unit FWIW). But I do have some concerns about how everything is currently plumbed under the sink - and thought if I'm going to get in there, I might as well fix anything that needs fixing.
I'm attaching a few photos of how it currently is setup.
My main concern is that the drain line between the wall and the trap runs slightly uphill, and that's likely causing the issues we've experienced with the right sink bowl backing up and leaving food crud in the bowl from time to time.
I've seen similar plumbing setups to ours before - but wondered if it's just that drain line that's really causing the problem? If there's a clogged trap issue as well? Or if I needed to run a separate trap and line to the drain line from each sink to alleviate the backup?
Any suggestions would be appreciated. Thanks in advance!
