Hello Everyone,
This is my first post to this forum and I was wondering if anyone could give a DIYer some advice or guidance?
I moved to a new house built in 1965 with copper lines through a monolithic slab foundation (no basement). The copper pipes still work good, but there are a few things I want to improve so I want to replumb the house. My reasons are listed below:
I will be using Uponor expansion pex, and I want to keep all fittings out of the attic. I plan to do a fare amount of extra insulation for the pipe in the attic (plus the recirculating hot) to keep things from freezing. We have several nights that get 20 below here. I have attached some pictures which show where I plan to run the lines. I want to do sub manifolds so I can keep all the connections in a common accessible location.
Let me know if you have any complaints!
- The copper pipes are old and in the slab, if and when they start having issues it will be hard to tell.
- The copper pipes have a large build up of iron or some other minerals. There is a lot of iron in the groundwater (well is the supply water) and seems previous owners did not use iron filters (I have one installed now), because its got quite the build up. The water always smells metallic.
- The entire house supply of hot water runs through 1/2 inch copper, which means its noticeable if several things are running at once.
- I want recirculating hot water, for instant hot water at the far end of my house where the main bath is.
- I plan to add another full bath in the future at the very opposite end of the house.
