imig93
Active Member
so i replaced my old valves with new ones…. when i turned the water back on it was dripping for a few mins then stopped?
1/4 angle stop valves under kitchen sinkWhat valves are you referring to?
1/4 turn angle stop compression valveWhat valves are you referring to?
did i break it? is there anything i can do ? i didnt tighten with a whole lot of force..but it was dripping a little then just stopped ??You could’ve over or under tightened the compression nuts.
Register today and take advantage of membership benefits.
