I’ve taken a hammer and beat the crap out of them until it half caved in.
Yeah, I have a temper.
You’re likely seeing the threaded caulking ferrule.Measuring across the top of the plug it measures ~4.25" What size is this?
Unlike the examples of 4" plugs I am looking at, the one in my clean-out seems to have a lip outside of the threads that is about 1/4" thick. This lip sits down on the top of the cast iron pipe. This is likely not necessary as far as a replacement goes but it's hard to know the diameter of the threaded part of the plug. I assume that it's 4" but I won't really know until I get it out.
Can I use a PVC plug as a replacement or does it need to be brass?
LMHmedchem
Can you direct me to any pictures of a setup like this?I would support anything I could to the joists, then I would buy (from a plumbing supply house) what's refereed tool as a steel friction clamp,or riser clamp you could put it just above the 1st wye and secure it to the joists with threaded rod and nuts 3/8"
Thanks, I will pick up the side beam hangers tomorrow. Most of the weight will be on the lower friction clamp that will sit under one of the hubs and be supported by 2x4s.I think I mentioned 2 spots for the friction clamp, one was near the base of the stack, supported by a 2×4 under each side. You could also put the other one higher under a hub securing it to the joists with what's called side beam hangers.
If you planing on putting it back in pvc,in mass you would have to keep it cast iron,that's code,unless your changing all to outside the house, where you not having it inspected , pvc will be fine, but the 4" couplings should be stainless steel 4band couplings husky is a very popular brand you won't find them at home Depot,were you transition from cat iron to pvc you would need a cast iron×pvc adapter (2) one for each end when you go back to cast iron, not sure were you want that 2 way clean out there is another fitting called a dandy clean out,that 2way clean out is usually used on pipe that's buried, let me know if this makes sense,Thanks, I will pick up the side beam hangers tomorrow. Most of the weight will be on the lower friction clamp that will sit under one of the hubs and be supported by 2x4s.
This is what I got for riser clamps,
2800-10 4" BLK RISER CLAMP
I am putting together a part list for the clean-out. I was thinking something like,
Charlotte Pipe 4in. DWV PVC Two-Way Cleanout ($22.63)
2x Fernco 4"x4" PVC DWV Mechanical Flexible Coupling ($9.86)
Charlotte Pipe 3" PVC DWV Fitting Cleanout Adapter with Cleanout Plug ($9.87)
Charlotte Pipe 4"x2' PVC Schedule 40 DWV Foam Core Pipe ($26.84)
Oatey 8 oz. Purple CPVC and PVC Primer and Regular Clear PVC Cement ($10.57)
First of all, I am not married to Home Depot. There is a Republic and a Ferguson here nearby and probably others as well. Republic doesn't seem to carry this kind of cleanout but only the "T" type. The Ferguson part is basically 3 times as expensive and is listed as a schedule 40 part. Is it worth it to pay the additional cost, meaning is the Ferguson (or some other part) more heavy duty, etc?
I find it very annoying that the most expensive item on the list is the 2' section of plain PVC pipe. I can't seem to find a "no-hub' PVC version of the cleanout. I could just use a "Y" but I would prefer a 2-way the would allow me to clean the stack above the fitting. Is there some other solution to marry the PVC hub to the cast iron?
I think this would be the best flexible coupling,
Fernco 1056-44RC 4in. Plastic Coupling with Stainless Steel Band ($34.67)
but I can't seem to find it in stock.
Republic has this clamp,
Huskey C400-HW 4" 4-Band Coupling (they don't post prices)
Would this be a good alternative or should I be looking at something else?
I know this is a great many questions but I would rather ask now as opposed to redoing things later.
LMHmedchem
If I understand you correctly, I would not be code for me to remove a section of the cast iron stack and replace it with a PVC clean-out. Is that correct?If you planing on putting it back in pvc, in mass you would have to keep it cast iron, that's code, unless your changing all to outside the house, where you not having it inspected, pvc will be fine, but the 4" couplings should be stainless steel 4band couplings husky is a very popular brand you won't find them at home Depot, were you transition from cat iron to pvc you would need a cast iron×pvc adapter (2) one for each end when you go back to cast iron, not sure were you want that 2 way clean out there is another fitting called a dandy clean out,that 2way clean out is usually used on pipe that's buried, let me know if this makes sense,
Not sure were you are in mass but metropolitan pipe is good their. In Woburn, web supply is in Boston, and Watertown, republic is in Norwood, and Framingham, oh yeh web is also in billerica
To install a clean-out in the stack and comply with code it would be necessary to install something like,
T56-044 4 NO-HUB DCO TEE W/4" RAISED HEX HEAD PLUG
with 2 no-hub clamps like,
C400-HW 4" HUSKY 4-BAND COUPLING
4 NH COUPLING 303-411 CINH4
Is this would you would recommend to comply with code? I can't see how I could possibly insert a cast iron clean-out with hubs into the stack so it looks like this is the only option for 2-way access. I could install a "Y" but I am having trouble finding anything with a 3" or 4" threaded plug as part of the Y.
You say that since I am not pulling a permit and having inspections that I could get away with PVC but that the part I listed is usually installed in a horizontal section of buried pipe. I suspect that it might not be strong enough to install with cast iron sitting on it. Do you agree?
LMHmedchem
I've seen pvc mixed with cast iron,if all you need is that clean out access I would just cut in the clean out just above the basement slop sink flood level, that way if you open the cover you not gonna get water leaking of the cap,there are sawzall blades made specifically to cut cast iron iuse the 4 band husky orange clamps
That would be these clamps?use the 4 band husky orange clamps
What side of the joist does the beam clamp fix to? Is it the bottom edge of the joist with the threading pointed at the stack, or is it the inside surface of the joist with the threading pointing to the floor?The flat side of the beam clamp goes against the joist
You probably need to replace your underground sanitary/sewer piping. I'm sure your sewer pipe just outside of your home (front porch) has collapsed and allows the dirt and roots to penetrate inside your pipe.Hello,
I have a clogged main line that allows some slow drainage. I have tried main line cleaner (which has worked in the past) but that did not do the trick and I need to look at more direct methods. I could really use some advice at this point.
This house was built sometime in the 1870s. A few years ago I replace the water line. At that point, the city inspector said that the line that was replaced was installed in 1920 (concrete lined steel pipe). My guess is that the sewer line was installed at the same time. The house may not have had indoor plumbing before that.
There is a 1950s double sink in the basement that is right next to the stack. That is where things always back up when there is an issue. I guess that's not such a bad place if it has to happen. The sink drains into 2" PVC that picks up the drain from the washing machine and the empties into the stack below the floor. A few years ago I re-did the plumbing under the sink because it didn't have enough pitch. At that point I put a union into the sink vent to give me some access to the main. Here is a picture of the setup,
The distance between the floor and the first flange in the pipe is a bit less than 44". The cast iron pipe is 4" OD. The 2" PVC to the left is the plumbing from the double sink. The horizontal 2" PVC at the bottom is the drain from the washing machine. The union in the 2" PVC is in the vent for the sink. The 2" PVC enters the stack below the floor somewhere. I didn't do that so I have no idea what the junction looks like.
If I run the basement sink, the sink it will eventually fill with water. The water will go down slowly, so some water it getting through. If I flush a toilet when the sink has water in it, that will end up in the sink as well. I have tried a gallon of main line cleaner by going overnight without using any water to hopefully let all the water drain down to the blockage. I then opened the union and poured the gallon in and left if for 8 hours without using any water. Then I flushed with hot water.
I can run the snake in further then I could before but I am still hitting an obstruction and the sink is still filling with water if I let it run. Based on my measurements with the snake, the obstruction is just on the other side of the outside wall, which puts it under the front porch. What is odd is that the snake hits something where I cannot push the snake through by hand. If I apply a little power with the drill, the snake goes right forward. I have done this with the sink full of water and punching through does not seem to affect the rate of drain. I have gone forward and backward with the snake. I have powered the snake in some and then pulled it back by hand. I have powered the snake in some distance and then ran it backwards while pulling it out. None of this seems to make any difference, which doesn't make sense. How can the snake go through but the drain not clear at least some?
There used to be access to a "house trap" about 3' in front of where the stack goes into the floor. There were wooded boards that you could take up and see the pipe surrounded with gravel. The pipe had a threaded plug. I took up the carpet and was very surprised to find no sign of the clean-out. It must have been concreted over when the carpet was put down. I don't remember doing that but it just isn't there anymore.
At any rate, I need access for a camera (I am not sure I can get a scope down the 2" with the union and through the elbow) or a power auger, or both. The old clean-out was just a "T" and wouldn't have allowed access with the power auger anyway (unless it was a very small diameter snake). My first thought was to brace the horizontal on the first Y on the stack and cut into the the 44" vertical section of 4" cast iron pipe. I could then use Fernco fittings to install a 4" DWV PVC "Y" fitting there. I am worried that the stack could be weakened by that and crate a disaster above. The other option would be to cut open the floor and find the old clean-out and replace that with a Y. That has me a bit worried about breaking the pipe while trying to get to it, though I could likely replace anything that broke.
Sorry for the rather long post but I could really use some advice here.
Thanks,
LMHmedchem
