Outside water faucet leak water when I use hose ( when turn on)
sanjay92
Jun 28, 2020
ca
Hi,
I am not sure whether that is back flow attachment to end of it that is causing leak when hose is attached and water is turned on. Currently water is spraying all over. I saw some youtube video's and they suggested that there is small set screw on back flow device and I looked all around but could not find any hole with any set screw. I even don't see any hole.
I tried unscrew using wrench with some pressure but it did not budge so I just want to make sure that I don't break anything while unscrewing.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,924
274
Boston, Massachusetts
Some of these have a spring inside that threads onto the original threads try to pull( with you hands) out and in thread it , if it doesn’t move you may have to cut it off using a hacksaw cut it in a few places without cutting into the original threads and peel back the brass
Jim Jensen
Feb 1, 2019
22
Jacksonville, FL
those have a set screw that is designed to BREAK-OFF after being screwed in, which supposedly makes them permanent, due to this STOOPID design, you have to cut them off..... a dremel tool or angle grinder would be the easiest way to do that...as Geofd said earlier.
