geoffhazel
I'm installing a new water heater in a daylight basement. It's about 12 feet from the wall where the exterior door is located. I figure I need to run a line from the heater to and through that wall and then right angle down to some distance off the ground. The wall the heater is on is a foundation wall that's been furred out with 2x4 wall.
What would be the normal setup for the pressure relief line? Inside the wall, or outside? Pex, pvc, or copper?
