I know this question is out of the norm, but it's a serious question.
I have a basement bathroom that is below grade and also below the exterior cesspool/septic tank. The main sewer line is about 4ft above the basement floor.
So anyone who is familiar with this type of setup and if you want a normal looking bathroom, you usually dig a hole in the basement floor so it's lower than the toilet and shower, and install a plastic sump. All the bathroom fixtures then are piped under the cement to a main 3 inch or 4 inch pipe and eventually drains into the plastic sump. Then a submersible pump is installed in the sump and it obviously ejects the sewage out of the sump(about 4ft in my case), and into the main sewage line that runs out to the exterior septic tank/cesspool.
That being said, I don't want to do it this way. I don't like the idea of submersion of a pump in the pool of sewage that eventually will need repair or replacing. Instead I want to sit a pump on the cement floor beside the plastic sewage tub and have only a 3" or 4" pipe, piped into it(and a vent of course). The pipe will pipe into a valve then a union then into the intake of the pump. The discharge will pipe to a check valve, union, and valve, and into the main sewage line.
I know this is abnormal for a residential system and I know the traditional way of doing it is usually what is used,, but again,, I don't want that. I'm sorry but I'm not interested in those saniflo type systems either, as I prefer the bathroom to look normal(toilet and shower flush with the floor).
I'm sure I need some sort of inline mascerator and inline pump or a combo of such to make this work, but I'm having trouble finding what I need(probably cause it's abnormal, or maybe I don't have the correct terminology to search for the items I need). I also plan to install a 2 prong water probe that will trigger a relay and power the pump. Maybe a high level probe as well in the event of pump failure.
In any event, if I cant find the items I need for this, I was thinking of using the submersible pump, but instead of placing it inside the sewage tub,, I would place it above the sewage tub and maybe I can weld a fitting on the bottom of it so it can be piped to, without submerging it.
In the end, I want the pump/mascerstor to be able to be easily isolated in the event of needing repair/replacement, without the mess.
Can someone please help me find what I need to accomplish this? Thank you
