No hot water at kitchen faucet?
Joecoolaug
Jun 9, 2018
Hi,
I have a strange problem I can’t figure out. My kitchen faucet has always worked great, but we decided to upgrade to a new model. Since then, we’ve been through 3 new models all of which turn to a trickle when set to hot water.
I’ve checked everything I can think of: the rest of the house has hot water and the disconnected hot water line has a full stream of hot water, but for some reason when connected to the faucet supply line, all that comes out is a lukewarm trickle. What are the odds I got three faulty faucets in a row? The new faucets are all the same type as the former: single handle with hot/cold mix.
What else could possibly be going on?
Only other recent change is a hot water dispenser that was installed 4 months ago connected to the hot water line, but this didn’t affect the hot water previously.
  • 65326619477__F0A210AC-7C56-4083-BFB7-E566B04162EB.MOV
    2.3 MB
havasu
Administrator
Staff member
Admin
Jan 5, 2010
10,817
2,391
Southern California,
You probably have sediment which needs to be flushed out. Before hooking up any faucet, put your supply lines into a bucket and work the valves open and closed a few times, then hook them up to the new faucet. You'd be surprised how much crap is in your water lines, which will clog faucets. Try removing the aerator to see if you can clear out the sediment.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
3,722
821
Boston, Massachusetts
Hi,
Also check your supply line to make sure it's not kinked
