Hello... Thanks in advance for any insight you may have...
I installed a new water heater today. All went well but the pressure release valve started to leak. I called the store, they gave me a new valve. I installed the new pressure release valve and it began to leak a shortly after install. Is it possible the two valves could be faulty? The valve on the heater I replace never leaked at all. The new water heater valve leaked before it even had a chance heat, so I don't think it was too much pressure due to heat.. It's a gas water heater from a big box store... I am regretting not calling a pro at this point. Both valves leak with rapid drips.
Thanks,
Larry
RE:
Thanks for all the replys...
The valve on the new tank leaked before the water was hot, 10 to 15 minutes after turning the water on.
I did lower the pressure to the house with no luck, still leaked.
The store gave me a new valve, it leaked as well.
The old tank that was replaced was not leaking from the pressure valve. If there was a pressure issue, would that old valve leak?
I am trying a new valve today from a plumbing store, not a big box store. If that does not work, I am calling a professional plumber to resolve this.
Thanks,
Larry
RE:
