jkk
Hello,
I am new at this site and need some information on the used Goulds pump that I have purchased for an emergency situation in case an existing pump fails while I get a new pump.
I really don't have much knowledge about the pump but some systems like how to install pressure tanks and pressure switches and electrical matters and how the system works etc.
I have a 230ft deep well and 120ft drop poly pipe replaced from galvanized pipe to poly pipe in 2016 with a 2hp 20gal Sta-Rite pump installed in Jan, 2006 by local well contractor
Also, I installed two 120 gal pressure tanks on 10 years ago with 40-60 psi setup and filter tank next to the pressure tank on 6 years ago by myself.
The reason I installed the filter tank was because when the drop pipe was a galvanized pipe which had produced so much rust debris from the pipe it caused plugging my mini irrigation system.
After replacing the poly pipe, there were no more debris problems but I never removed it.
The main water pvc pipe runs about 350 ft from the well and 15 ft lower elevation.
Also, installed DEFINITE PURPOSE CONTACTOR for main switch.
The well system never had any problem except replacing the pressure switch one time.
Recently, there was no water in the house. I thought the well pump failed because of age but it wasn't. but the main pvc pipe was broken and repaired easily.
But I was very concerned about sudden no water so I bought a reconditioned well pump from a local guy who rebuilt the old pump
The model number is 13EM1-5412 and the guy told me the pump is 13 stage and 13 gpm 1 1/2 hp.
I couldn't find any info for the pump online.
My question is if members here have any information for the pump and whether the pump should be good for temporary usage or not.( i have a new 2hp control box)
Thanks in advance.
Jkk
Thanks in advance.
Jkk
