need routine drain maintenance suggestions
Rita_G
Mar 6, 2012
7
Scenario:
About every 3-4 years, the sinks/showers (not toilets) on one side of house (kitchen side) begin to clog, and a sewer/drain clog guy has to come with motorized snaking device to clear the pipe, and says it was clogged with grease. Same thing every time.
Question:
Is there any way to routinely maintain the drainage system to avoid clogging with grease?
voletl
Dec 17, 2014
800
249
New York
Snaking a line clogged with grease is a temporary fix the snake only punches a small hole through the clog it will fill back up soon IE your sistuation
Either jet the line or replace the line
Diehard
Aug 19, 2017
2,640
469
North Reading, Mass.
Also, if you do not have a septic tank system, I would suggest that you look into chemical drain cleaners for grease. Making sure it's safe for your piping, of course.
The best drain cleaners for grease are often liquid cleaners that can dissolve and dislodge even the toughest clogs without you having to call a plumber.
You can start with this write-up.
https://www.bustle.com/p/the-4-best-drain-cleaners-for-grease-12111162
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,932
279
Boston, Massachusetts
I would throw 99% of your food scraps in the trash I deal with drains every day commercial residential,disposal or no disposal after time your drain will build up with grease/debris the more you keep the food out of the drain the less you will see the drain cleaner
