Need help removing/identifying shower faucet valve
curttard
Dec 9, 2014
9
Hi, I have a leaky shower, problem seems to be the cold faucet. It's a two handle Kohler (at least the handles are Kohler), probably the original from when the house was built in 1989.
When I open up the handle and remove the plastic stem extender, the attached pic is what I see. A moderate amount of force doesn't pull the valve out and I don't want to pull too hard because I don't know if there is a lock ring or nut or retaining clip or tab or something else that needs to happen first.
Any ideas? Kohler support was no help. The closest part I can guess which looks similar but doesn't have the white cap/seal looking thing is Kohler GP76671: https://lh3.googleusercontent.com/proxy/LozyRZeA-YlAI4xY5TazCrgKIwv0I7OL_N9mHSxwnhGXUbglHYYi1YqooKgVPJOjBgEkpFlmqOI8zTbndmNt9xF47bLzRaZTJZUJAPosJrDJaqJlfLfOfDn-OBOrRo5PBA
Twowaxhack
Professional
Professional
Feb 9, 2021
2,690
1,069
United states
Use something to hold the valve steady in the wall while you pull straight out on the cartridge. That’s if the valve is loose
You might have to get rough with it.
It’s a Kohler coralais
Rickyman
Feb 5, 2018
328
188
Have your new cartridge in hand first. Thread a screw into the cartridge then use the claw of a hammer on the screw to gently pry it out. Protect the tile with a piece of wood so you don’t damage it with the hammer
curttard
Dec 9, 2014
9
Ok, so no tab or clip or anything that needs to be released first? That helps a lot, I will try to work it free. I saw the screw tip on the Amazon comments for the GP76671 part, but wasn't even sure that was the right part.
Twowaxhack
Professional
Professional
Feb 9, 2021
2,690
1,069
United states
No, the nut you removed holds it in. Wiggle and pull straight out. The o rings swell up a little and lock it in place.
I’ve also turned water back on for quick second to blow it out before. I had helper on telephone inside while I was at main valve.
exciting 🤓
curttard
Dec 9, 2014
9
exciting 🤓
I didn't actually remove any nut. There was the screw holding the handle knob on, then a long metal cylinder that screwed on over the whole deal (I guess this must have been holding it all together?), then plastic stem extender that just slid off.
Twowaxhack
Professional
Professional
Feb 9, 2021
2,690
1,069
United states
That’s what I’m calling the nut. It screw over the valve body to hold the cartridge in the valve.
curttard
Dec 9, 2014
9
Thanks to both of you, all fixed now! Kohler even sent me the replacement cartridge for free.
