corvairbob
Active Member
i have been trying to help some people fix there shower valve. it has STH on the bottom of the body and it has 2 different valve stems in it. on looks like a npt thread and one looks like most i have seen on websites that has the shoulder and a gasket to seal the stem in the body.
the seat is maybe 1" long and it looks like it has a square area in the bottom for a seat wrench but my seat wrench tool will not even come close to going into the seat for removing it. i can get a 1/4" allen wrench down inside the seat and then i hit that area for the normal wrench would go to remove it. more than likely i will wind up drilling the seat out and installing new ones, but i have to find out what seat it takes.
i have photos of the stem and what the seat looks like with what appears to be notches for the wrench. but now i will have to find a wrench for this unless i can make one out of some key stock.
so i think i have located the stems but with photos and numbers i hope you can tell me for sure. and help with the seats. if they only make a few sizes in the long seats i will just get a kit and then i should have one that works.
here are some photos of what i'm up against and i sure hope someone here can help me find the parts for this so i can help those folks out. she is of work from surgery and he is a disabled vet
first 3 are the seat i just took out and got numbers across then threads for the body of the stem i have .738" across the stem that holds the rubber washer i have .438" and the overall length is 1.543"
the nest photo is the other seat that i had to rework to get the huge divit out of it so they could shut off the water. and inside that i think you can see the notches for the removal tool but i have to find a tool to remove these and install new seats. maybe you can help me onthat tool? part number? or store that has them?
the last photo is the numbers i got from the stem valve the other part is my interpretation of what i think the seat might look like bases on looking at the thing up close. this photo is the one i refinished and it looks like it is not done but it has about 75% flat surface at that divit you see around the 10 o'clock spot. i figure if i can get new seats and i get a removal tool that fits but then will not get the seats out i can drill them and then use a punch to try for the remaining parts or use left hand drills to drill it out and hope that they then just work free form the heat of drilling. i do not want to put a torch on this for fear of damage to the body or the shower wall. the other side stem looks like a npt thread as it fit into a coupling easy and just about all the way but it is possible it is a straight thread and just magooed up some lats photo and i had to cobble this so they could have the water turned back on and the shower not run but it is just about out of working threads and will soon strip out for sure it is shown in the full closed position and when i turned the handle 1/2 turn more it was at the end of those working threads
so can anyone help me figure this one out? thanks
