I have been studying the low flow indicator on my water meter. The triangle moves EVER SO SLIGHTLY over a matter of minutes. It is calibrated to .1 Gallons for 1 revolution. If it moves 10 degrees in 5 minutes that is a lot. I only noticed it by taking a video of it and then fast forwarding to notice the movement. Is it possible that the movement could be caused by something other than a miniscule leak? I have checked all of the toilets and sinks. Nothing is wet. My baseboard heat is not wet. My furnace, water softener, and hot water heater are all secure. I do live on a slab so some of the baseboard pipes and water lines are under the slab, but nothing is damp, warped, or crumbling. Any advice? Could this just be from pressure changes on the street? or possibly from my furnace auto-bleeding on occasion? Something else I am not considering?
