Chris Jackson
- Is it possible for me to check if there is a leak on my pipes? How can I check by myself if there are leaks?
Yes! Only takes a minute.What are the OP’s previous comments?
Are you saying I should go hunting for his comments or questions in other threads?
Making a lot of assumption on the question.
#1 Always plumb in a static gauge in an acceptable location that allows you to monitor system pressure at a glance.
That gauge is fine. I like the oil dampening as it ensures a long life. Should find similar in a local hdwr store. I’ve had one on a tee at the garage’s john since 96. Saved my butt last yr.Is this Renator gauge reliable enough to be actively (connected) all the time?
http://www.amazon.com/Renator-M11-0504T-Oil-Filled-Pressure-Gauge/dp/B07TTV3PVH
