brighamandrew
I'm learning to replace a kitchen sink for the first time myself. The sink is a single bowl which will have a garbage disposal in the center. The garbage disposal will not clear the previous drain pipe leading into the wall. The pipe appears to have been glued together. I want to replace this pipe with one that would give the garbage disposal room. How would I go about replacing this pipe? Thank you.
