john kinaschuk
- Joined
- Sep 12, 2023
- Messages
- 5
- Reaction score
- 1
Not sure why location would make a difference for a bath tub? But if it helps, yes, I’m in Canada.It may help our professionals to let them know you are in Canada.
Sorry, I thought I had put the issue in there. It is leaking at the glued joint coming off the tub. It is definitely part of the water pump system, not air system. I basically want to know if I can replace it with a male by female elbow or if it needs that ball and seat for some purpose.What’s wrong with it ? It may be part of an air intake but I really don’t know.
Makes sense. Thanks for the input.That may be where an air control would connect.
Jetted tubs sometimes have an air intake that that might be where it would connect if it had one. It mixes air with the water.
Other then that I can’t help you. All that piping is done at the factory.
