Jet pump end of life or is there something else wrong
If it is intermittent you may have a bad check valve. Next time is sounds like that and fails to shut off, close the ball valve on the suction line. If it sounds the same, something else is blocking your suction. It could be a bad check valve or a clogged well screen.
