johnny7
Hi all, I have jet pump and pressure tank. I’ve had it for about 10 years now. Normally, the system kicks in, pressurizes the system and shuts off. Over the last few weeks, I’ve heard it kick in, start to pressurized, but then it never shuts off, it keeps running. I turn the pump off, count to 5, turn it back on, and it pressurizes no issues. This only happens once every couple of days so not consistent at all.
Yesterday, I went down and documented the pressure settings and tested it. When I was down there, I noticed that when the pump kicked in, it sounded funny, like there was an air lock in the system. It pressurized each time I did my test. I took a video to show what it was doing. Side note, all settings were what they are supposed to be 50/30 and the tank is 2.4lbs below cut in pressure.
There are no leaks in the system and my water tanks are right beside the pump so there shouldn’t be any air in the system at all. In fact, if there was air in the system, we would notice it in the faucets spitting. Pictures attached.
So do I have a pump that is starting to fail? I have no problem purchasing a new pump but I’d like to know that this one is having issues.
Hardware
Canadian Tire Mastercraft 062-3590-8 pump
Pressure tank Flexcon PJR 25S
Hardware
