JG plumbing
When I look at the pictures of this fitting to me there is an obvious difference between the T and the double Inlet t. If the radius is equivalent then it should be fine but it doesn't look like it is. The manufacturers try to get away with changing as little as possible to their dies and manufacting process. The article highlighted above is saying if the manufacturer can make a fitting that does x them it'll be legal in that position.
It looks nothing like the sanitary tee radius.
You can't shoot poop into other fixture lines. Branch lines aren't designed to clean obstructions that are sitting in the pipe. They are designed to carry solids that are floating.
