They are installed vertically here, that is the wall (not floor). There will be a 3” pipe extending 2 feet into a closet elbow.
Use a sanitary tee instead of the combination.
Use the wisconsin in the vertical position.
That looks great. I’d hire you.If I twist the Wisconsin fitting I eliminate the need for those two LT 90 elbows. I now use a 45 to my 2” run and a 45 to my 3” run. This should give optimal flow.
The Wisconsin fitting does have a sanitary T 2” inlet so everything seems perfect now.
