Mikieboyblue
I have to actually replace this because it back slopes toward the sink and I need to make sure the drain wasn't compromised by whomever or whatever caused that extensive stud decay / charing.
Is using a why like this legit under IPC or UPC?
Thanks!
Mike
PS. Yes I realize you shouldn't drill through the king and trim studs in a load bearing wall and under a window, but it was already like this. The holes are virtually notching the 2x4. I will probably try to sure up the damaged one.
Thanks!
Mike
