- See now? I'm "learning." This is Great! ;-) You likely don't care but 40 years ago, the first time I ever watched a licensed plumber work on a house and try to learn something - we were putting a toilet in an attic apartment above an existing toilet. I remember him telling me that you can't "dump in a vent" and then (near as I can tell) that's how he did it anyway. Follow that up with the basement toilet in our last house - also plumbed into existing stack with no extra vent. It leaves us dummies confused! (I imagine one of the more common DIY atrocities that you guys run into?)... Okay so... New toilet is planned about t feet from existing drain line. It'll need it's own vent. I'm still hoping I can do that, tie it in with vents for sink and shower and run it to what is clearly a two inch vent pipe running out of the laundry room and then along side the stack to a point above the upstairs toilet and tying back in. - Is that all good?? On the attached again... Red and green on the right is stack and existing (broken) wye. I want to run a 4" drain from the wye to the new toilet (circled in red) - (about 7 feet). Behind the toilet I'd add a vent and a tee so as to tie in drain from sink/shower. (circled in blue). Yellow area is existing bathroom (my guess is DWV plumbed "wrong"). -- Will it work? and again - still cut into stack? or just remove/replace wye? And also, again, thank you for being patient, it's a rare find on these forums.
