I’m not handy but I can make a great sandwich.
GreenRed
Feb 12, 2021
5
Canada
Hello 🙋‍♂️,
I want to install some shut off valves under the kitchen sink and have these fittings with pex to copper.
Looking for input on what I should use for shut off values?
thanks
That’s either 1/2” or 3/8”’ SDR-9 pex.
Can you measure the diameter ?
Where do you want to put the shutoffs?
At the location shown in your pic, which looks like a union type of fitting?
Or do you want to splice them in lower down, which is what I would do.
With either a Sharkbite pex to pex shutoff, or use pex to pex crimp shutoff if you have the tool.
The picture is showing a pex faucet adapter fitting. It transitions from pex to the faucet inlet.
I see these a lot in Manobloc type systems.
Manobloc systems can use 3/8” ID tube ran directly to each fixture. Each fixture has a cut off at the main manifold usually located in the garage, laundry room, etc.
No cut offs under the fixture.
That’s why I asked what size his pipe was.
The pex is 1/2, I assume since the fitting below is “1/2 pex” see image.
You need a 1/2” pex x 3/8” od straight stop valve and a 3/8” x 12” faucet connector.
The valve can be crimp on with the ring or you can go push fit. I’d go crimp, but I’m also a pro and have the tools and experience.
Good luck to you sir.👍✌️
Thanks, I think I like Jeff’s idea of cutting the pex further down, any cons to doing that?
I have no experience with Manoblock systems.
It sounds like they are set up like electrical systems, with home runs to a manifold with service stops, kind of like house wiring leading to a breaker box.
EDIT oops “ManaBloc”
Exactly but worse. It would be like having a breaker for every outlet or light fixture. 😬
Sure, cut wherever you’d like, just get a long enough faucet flex line.
Can’t he just splice in a pex to pex straight stop, and leave the faucet supply connection as is?
But then, his next faucet might have different length of supply lines built in.
