How to remove this from hose bib
Discussion in 'General Plumbing Help' started by PlumbGate, Apr 17, 2019 at 12:51 AM.
  1. Apr 17, 2019 at 12:51 AM #1
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    101
    16
    Maryland
    How do I remove the below from my hose bib? Every time I turn off the water it sprays water all over me. I see no use for it at all as I properly winterize and drain my faucets from inside. I see no obvious method of removing it when I turn it it seems to just spin.
  2. Apr 17, 2019 at 6:48 AM #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,022
    2,197
    It has been ''locked''
    you need to use your dremel tool with a cut off abrasive blade
    cut it where shown in the picture
    being careful not to cut the threads, and peel off with a screwdriver
  3. Apr 17, 2019 at 12:46 PM #3
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    101
    16
    Maryland
    I was afraid I would have to cut it off. Thanks I will break out the dremel!
    frodo likes this.
  4. Apr 17, 2019 at 1:14 PM #4
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,022
    2,197
    once that set screw is set and broke off.
    it's all over ,
    they need to make those with tamper proof set screws
    so they can be removed with out destroying it
    PlumbGate likes this.
  5. Apr 17, 2019 at 2:51 PM #5
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    196
    27
    Northwest Washington
    I think they do that on purpose -- they don't want you to remove it. Ever.
    frodo likes this.
  6. Apr 17, 2019 at 3:52 PM #6
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    101
    16
    Maryland
    I wonder if I could just dremel a slot in the broken off set screw and unscrew it. Wouldn't hurt to try I guess!
  7. Apr 18, 2019 at 2:32 AM #7
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,022
    2,197
    that set screw is as big as a
    I 6''.png There is a youtube that shows a guy doing that
    but if you look close, he replaced the set screw with a bolt
    the video is fake as hell
    Anything is worth a try
    from the video
Share This Page
