We purchased and had professionally installed a Vasilis Shower System. It has a 40mm HJ-40 cartridge in the valve. Immediately after install we noticed a knocking sound when any other water is turned on or off in the house from the wall of the shower. It especially occurs when the washer is running (water hammer). After intense searching for pipes, we were able to isolate the cause of the knocking to the shower mixer valve. When we removed the valve we noticed that when you shake the valve, a cylindrical metal piece slides back and forth- which creates the noise. We thought that replacing the cartridge would fix it, so we ordered an exact replacement
https://www.amazon.com/dp/B00DVLQXR4/?tag=skimlinks_replacement-20
The new cartridge makes the same noise! This must be a design flaw. Is there any way to fix this, or another cartridge type that I can use? This is driving me insane. I even installed water hammer suppressors on the washer, but this knock is so sensitive it even does it when sink faucets go on and off. No other showers in the house make this noise.
Please help! Suggestions?
